I have 2 stand alone APs at work which have no problem to accomplish 650-866 Mbps @ 80Mhz/2S/SGI however at my home environment I cannot accomplish more than 80MHZ/1S/SGi @ 433 Mbps on the exact same devices using CAPsMAN.
What am I doing wrong?
I have posted my config below. Any ideas?
# jul/22/2020 RouterOS 6.47.1
/caps-man channel add band=5ghz-onlyac control-channel-width=20mhz extension-channel=eCee name=5ghz reselect-interval=1h tx-power=20
/caps-man channel add band=2ghz-onlyn control-channel-width=20mhz extension-channel=eC name=2ghz reselect-interval=1h tx-power=20
/caps-man rates add basic=54Mbps ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 name=2ghz-rate supported=54Mbps
/caps-man rates add basic=54Mbps ht-basic-mcs="" ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 name=5ghz-rate supported=54Mbps vht-basic-mcs=mcs0-7 vht-supported-mcs=mcs0-9
/caps-man security add authentication-types=wpa2-psk encryption=aes-ccm name=WiFi passphrase=password
/caps-man security add authentication-types=wpa2-psk encryption=aes-ccm name=WiFi-Guest passphrase=password
/caps-man configuration add channel=2ghz country=canada2 datapath=WiFi-LAN distance=indoors installation=indoor mode=ap name="2ghz-WiFi 2.4" rates=2ghz-rate rx-chains=0,1,2,3 security=WiFi ssid="WiFi 2.4" tx-chains=0,1,2,3
/caps-man configuration add channel=2ghz country=canada2 datapath=WiFi-LAN datapath.vlan-id=200 datapath.vlan-mode=use-tag distance=indoors installation=indoor mode=ap name=2ghz-WiFi-Guest rates=2ghz-rate rx-chains=0,1,2,3 security=WiFi-Guest ssid=WiFi-Guest tx-chains=0,1,2,3
/caps-man configuration add channel=5ghz country=canada2 datapath=WiFi-LAN distance=indoors installation=indoor mode=ap name=5ghz-WiFi rates=5ghz-rate rx-chains=0,1,2,3 security=WiFi ssid=WiFi tx-chains=0,1,2,3
/caps-man configuration add channel=5ghz country=canada2 datapath=WiFi-LAN datapath.vlan-id=200 datapath.vlan-mode=use-tag distance=indoors installation=indoor mode=ap name=5ghz-WiFi-Guest rates=5ghz-rate rx-chains=0,1,2,3 security=WiFi-Guest ssid=WiFi-Guest tx-chains=0,1,2,3
/caps-man datapath add bridge=BRIDGE client-to-client-forwarding=yes name=WiFi-LAN
/caps-man interface add configuration=5ghz-WiFi disabled=no l2mtu=1600 mac-address=CC:2D:E0:EA:79:9D master-interface=none name="WiFi - Basement" radio-mac=CC:2D:E0:EA:79:9D radio-name=CC2DE0EA799D
/caps-man interface add configuration=5ghz-WiFi disabled=no l2mtu=1600 mac-address=CC:2D:E0:EA:79:B9 master-interface=none name="WiFi - Upstairs" radio-mac=CC:2D:E0:EA:79:B9 radio-name=CC2DE0EA79B9
/caps-man interface add configuration="2ghz-WiFi 2.4" disabled=no l2mtu=1600 mac-address=CC:2D:E0:EA:79:9C master-interface=none name="WiFi 2.4 - Basement" radio-mac=CC:2D:E0:EA:79:9C radio-name=CC2DE0EA799C
/caps-man interface add configuration="2ghz-WiFi 2.4" disabled=no l2mtu=1600 mac-address=D4:CA:6D:2B:90:5E master-interface=none name="WiFi 2.4 - Outdoor" radio-mac=D4:CA:6D:2B:90:5E radio-name=D4CA6D2B905E
/caps-man interface add configuration="2ghz-WiFi 2.4" disabled=no l2mtu=1600 mac-address=CC:2D:E0:EA:79:B8 master-interface=none name="WiFi 2.4 - Upstairs" radio-mac=CC:2D:E0:EA:79:B8 radio-name=CC2DE0EA79B8
/caps-man interface add configuration=5ghz-WiFi-Guest disabled=no l2mtu=1600 mac-address=CE:2D:E0:EA:79:9D master-interface="WiFi - Basement" name="WiFi Guest - Basement" radio-mac=00:00:00:00:00:00 radio-name=CE2DE0EA799D
/caps-man interface add configuration=5ghz-WiFi-Guest disabled=no l2mtu=1600 mac-address=CE:2D:E0:EA:79:B9 master-interface="WiFi - Upstairs" name="WiFi Guest - Upstairs" radio-mac=00:00:00:00:00:00 radio-name=CE2DE0EA79B9
/caps-man interface add configuration=2ghz-WiFi-Guest disabled=no l2mtu=1600 mac-address=CE:2D:E0:EA:79:9C master-interface="WiFi 2.4 - Basement" name="WiFi Guest 2.4 - Basement" radio-mac=00:00:00:00:00:00 radio-name=CE2DE0EA799C
/caps-man interface add configuration=2ghz-WiFi-Guest disabled=no l2mtu=1600 mac-address=D6:CA:6D:2B:90:5E master-interface="WiFi 2.4 - Outdoor" name="WiFi Guest 2.4 - Outdoor" radio-mac=00:00:00:00:00:00 radio-name=D6CA6D2B905E
/caps-man interface add configuration=2ghz-WiFi-Guest disabled=no l2mtu=1600 mac-address=CE:2D:E0:EA:79:B8 master-interface="WiFi 2.4 - Upstairs" name="WiFi Guest 2.4 - Upstairs" radio-mac=00:00:00:00:00:00 radio-name=CE2DE0EA79B8
/caps-man manager set enabled=yes
/caps-man provisioning add action=create-enabled master-configuration="2ghz-WiFi 2.4" name-format=prefix-identity name-prefix=2ghz radio-mac=CC:2D:E0:EA:79:B8 slave-configurations=2ghz-WiFi-Guest
/caps-man provisioning add action=create-enabled master-configuration="2ghz-WiFi 2.4" name-format=prefix-identity name-prefix=2ghz radio-mac=D4:CA:6D:2B:90:5E slave-configurations=2ghz-WiFi-Guest
/caps-man provisioning add action=create-enabled master-configuration=5ghz-WiFi name-format=prefix-identity name-prefix=5ghz radio-mac=CC:2D:E0:EA:79:B9 slave-configurations=5ghz-WiFi-Guest
/caps-man provisioning add action=create-enabled master-configuration="2ghz-WiFi 2.4" name-format=prefix-identity name-prefix=2ghz radio-mac=CC:2D:E0:EA:79:9C slave-configurations=2ghz-WiFi-Guest
/caps-man provisioning add action=create-enabled master-configuration=5ghz-WiFi name-format=prefix-identity name-prefix=5ghz radio-mac=CC:2D:E0:EA:79:9D slave-configurations=5ghz-WiFi-Guest
This is a what is being using on the stand alone AP:
/interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik
/interface wireless security-profiles add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=WPA2-WiFi supplicant-identity="" wpa2-pre-shared-key=password
/interface wireless security-profiles add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=WPA2-WiFi-Guest-WiFi supplicant-identity="" wpa2-pre-shared-key=password
/interface wireless set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=5ghz-n/ac channel-width=20/40/80mhz-XXXX country=canada disabled=no distance=indoors frequency=auto hw-retries=10 mode=ap-bridge name=wlan5ghz-WiFi security-profile=WPA2-WiFi ssid=WiFi wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
/interface wireless add disabled=no keepalive-frames=disabled mac-address=CE:2D:E0:EA:80:A1 master-interface=wlan5ghz-WiFi multicast-buffering=disabled name=wlan5ghz-WiFi-Guest security-profile=WPA2-WiFi-Guest-WiFi ssid=WiFi-Guest wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/interface wireless set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-XX country=canada disabled=no distance=indoors frequency=auto hw-retries=10 mode=ap-bridge name=wlan24ghz-WiFi security-profile=WPA2-WiFi ssid=WiFi wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
/interface wireless add disabled=no keepalive-frames=disabled mac-address=CE:2D:E0:EA:80:A0 master-interface=wlan24ghz-WiFi multicast-buffering=disabled name=wlan24ghz-WiFi-Guest security-profile=WPA2-WiFi-Guest-WiFi ssid=WiFi-Guest wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
