433 + R2N stop traffic data
Hi, I have a problem with this device. I have an RB433 with 2 R2N (set in 11B), configured as Ap-brdige all in Bridge.
One of the sectors stops transmitting data, but customers are not disconnected, stop having ping to customers. The only way to return to the board walk is disabling and enabling the R2N again.
Nothing appears unusual in the logs.
Hola a todos , tengo un problema con este dispositivo. Tengo un RB433 con 2 R2N ( set in 11B), configurado como Ap-brdige todo en un Bridge.
Uno de los sectores deja de transmitir datos pero los clientes no se desconectan , deje de tener ping hacia clientes .La unica forma de que vuelva a andar es deshabilitando la placa y habilitando la R2N de nuevo.
No aparece nada raro en los logs.
please make the support output file when you see such problem and send it to support@mikrotik.com
Ok i will do , thk
I have sent the file, I’ll be waiting for a response
