Recently had 433AH lockup on me. After climbing a tower and replacing the board, I hooked up a serial null-modem cable to the board and tried accessing it with HyperTerminal. Below is the error message I received.
Can anyone tell me what’s wrong and if it can be fixed?
CPU frequency: 680 MHz
Memory size: 128 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Oops[#1]:
Cpu 0
$ 0 : 00000000 1000c600 00000008 00000100
$ 4 : c798c000 c789a480 c0372000 c01f5e04
$ 8 : 00000000 c020b4d0 80204400 14066dfc
$12 : 08000000 40008100 50808928 00000400
$16 : c789a480 c798c000 ffffffff c023e4e4
$20 : c0361b60 00000000 00000000 00000000
$24 : 00000000 00000000
$28 : c7824000 c7825eb0 00000000 c01f6990
Hi : fffffff0
Lo : 8f8f8f9f
epc : c01f53a4 elevator_init_queue+0x4/0x10
Not tainted
ra : c01f6990 elevator_init+0xb4/0x10c
Status: 1000c603 KERNEL EXL IE
Cause : 00800008
BadVA : 00000044
PrId : 00019374 (MIPS 24K)
Process swapper (pid: 1, threadinfo=c7824000, task=c7820000, tls=00000000)
Stack : 00000000 00000000 00000000 c0348150 c798c000 c7911850 c01f85dc c01f85bc
c01fed88 00000000 c0236298 00000008 ffffffff c0186738 c7911848 c034a890
c0350000 00000000 c023ebc0 c023eb4c 00000000 c0361b48 c036fac0 c0361a88
c036fac8 c036fb1c 00000000 c0370000 c010145c c010145c c7845900 c03462b8
000000ff c0380000 c01cbc10 c01cbbfc 00326366 c01cb868 c7825f60 00000000
Call Trace:
[] elevator_init_queue+0x4/0x10
[] elevator_init+0xb4/0x10c
[] blk_init_queue_node+0x124/0x17c
[] register_mtd_blktrans+0xa8/0x228
[] do_one_initcall+0x5c/0x1ac
Code: 03e00008 27bd0018 8ca20000 <8c59003c> 03200008 00000000 8ca30040 106
—[ end trace 4d3fbdbbef9429b6 ]—
Kernel panic - not syncing: Attempted to kill init!
