433AH with 2 Radios 2.4 AP & 5. Backhaul Setup
I need help configuring MikroTik 433AH with 2 Radios
Need help in detail to configure this unit with the following way using winbox.
2.4 AP with Dhcp Server with address pool in the 10.0.0.x range on radio 1
5 Ghz on the Client/station Backhaul Link on radio 2
I already have a 5Ghz AP with at my office to send to Tower location Backhaul Radio
If i need to awnser any questions in further detail or post screenshots of winbox just ask.
Really Appreciate the help here.
I set up the backhaul first and insure all is well there. Then I set up the AP radio once that is operational.
Assign an ip address to the backhaul radio in the same range as the backhaul AP.
Set up the radio as station with ssid band and frequency the same as the AP.
Add a default route to the gateway on the backhaul AP.
Insure you can ping the new unit’s ip from the current backhaul AP.
Set up dns.
Set up NTP if needed.
Since you mentioned dhcp, I will presume you want to route the localnet ips back to this router from the current backhaul AP and not just bridge it. Correct?
If you need help, include the localnet ip/netmask of the current backhaul radio.
Thank You For The Help
