can ayone give me ideas what to look at if my 433 keeps freezing up i uninstalled all the stuff im not using took out the micro sdcard
but it still frezzes up after 2-3 days
any ideas what this is
i have change the powersupply
and still the same thing
what do you mean by “freezes”? what is shown on the Serial Console output? Can you make a supout.rif file right after you reboot it, and send to support?
well if i turn off the power and turn it on again it works
and with the serial cable its hard to get to !
so when it happens ill make a suport file again and send it to support
probably, support will be able to tell you the cause of the freeze.
