hi
im having a problem with my 3 days new mikrotik 450G. ethernet port 4 no action when i’m plugin the network to laptop. this is hardware issue or something configuration ? here i give my configuration port.
/interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1... 1500 00:0C:42:A0:97:E2 enabled none switch1
1 R ether2... 1500 00:0C:42:A0:97:E3 enabled none switch1
2 R ether3... 1500 00:0C:42:A0:97:E4 enabled none switch1
3 ether4... 1500 00:0C:42:A0:97:E5 enabled none switch1
4 ether5... 1500 00:0C:42:A0:97:E6 enabled none switch1
edit : i just reset to factory. but still the same no light on port 4, any suggest or something that can be done ? thanks ![]()
