47 km link problem !!!
Hello, I have a problem with a 47 km direct view link, NETMETAL equipment and antenna MANTP30 PA signal -51, then -70 then disconnect for a few seconds, then again connect, sometimes even ping between the equipment. I mention that the two antennas can be seen between them sometimes when the pillars are clear, so direct visibility. I changed the channel, in vain, I switched on the menu everything that could … why is it disconnected? Quality sometimes occurs at 24% and sometimes up to 34%. Please help me, I hurt for a week. Thank you!
Did you Use nv2?
How high is your Output power?
Hy, i solve problem now, at wireless protocol eas any, is rong , i put nstream and works!!! Incrediblee!!!
