48 volt power to Routerboard
Does Routerboard have a unit that can be feed with DC Power. We have 48 volt rectifier systems at some of our sites. We try to put all important equipment behind them. Can Routerboard support this configuration or will it require a UPS at these sites. Thanks in advance for all of your help.
for example
http://routerboard.com/RB800
http://routerboard.com/RB600A
or you can use converter from 48V to 24V
http://routerboard.com/RBPOE-CON-HP
That is great thanks for the info. Is there a way to do it with this piece of hardware?
http://routerboard.com/CCR1036-12G-4S-EM
I really appreciate the help. Thank you thank you.
Troy
The CCR1036-12G-4S-EM has two Power Supply headers on the board. One is in use by the factory shipped AC/DC Power supply. The other is vacant for primary/redundant Power Source.
This board also runs @ 24VDC, so you’d still need to step down the power to 24VDC. I use Meanwell DC/DC Power Supplies to step down/up power when needed.
Wild Bill,
Thanks so much for the response. I really appreciate the help I will step it down. Thanks for the great support.
I will plan to order a few of these.
Thanks,
-tb
