Is the combination of a -48V power supply (PW48V-12V85W) and an AC power supply a supported configuration? CCR2116 is my likely target.
It show’s that combination in the brochure, and even mentions that specific combination in the product description. Did you try it and are having problems?
The PW48V-12V85W work regardless - or + 48V
The + or - on voltage do not mean to “cross” the DC cables to power the device, but:
-48V = positive on the chassis/ground
48V = is supposed +48V but better know if is one error…
+48V = negative on the chassis/ground
I have the same configuration, also mixed on the same rack devices with “-” and “+”, and all work as expected, without short-circuits,
because both the AC and DC power sources are galvanically isolated
but better do some test woth your other equipments before do any…
Exactly what I need to know... again. Thanks!
I didn’t, I missed that in the description somehow… “Simply remove one of the current power supplies…”; implying that mixing them is ok.
I have some brands where this is explicitly not supported and needed to be sure, I want to keep the magic smoke where it belongs.
Thanks!
