-48vdc router
Hi Guys,
Where can I urgently order a Mikrotik Router with 2 PSU for Datacenter with -48vdc?
Regards
+1.
++ here as well!
Been needing this for a while also.
If I do not see any replies I will assume Mikrotik ROuters are simply not ready for Datacenters…:frowning:
just use RB800 with plug and poe.
I need a rackmount unit for an OC3 connectivity.
It will handle alot of BGP Traffic.
Any other suggestions?
Regards
if you are using high quality PSU units you can replace current PSUs with -48DC to 24V ones. After all you are allowed to open case. If you damage router with your new PSU you will have problems. But if that does not happen you will not void your warranty for the router.
Good news.
Where do I get the PSU units?
Regards
search the forum,
Somebody posted already a picture with a second DC PSU in a CCR.
found the thread
http://forum.mikrotik.com/t/48v-mikrotik/81065/1
Sweet… so what CCR models would that work on? Could one replace the single PS of the 1009-8G-1S with one of these? Or both PSes in a dual-PS model?
(My boss is very telco-oriented, I think this just sold him on a CCR or two for me to “play” with.)
it is better to replace existing PSU. For routers that already come with 2 PSUs you can replace one or both of them.
