I’m interested if any of you met with the following: RB493G’s eth just stopped communication (gigabit connection with PoE). It’s connected to a RB2011. Both sides UP. If i set both side no-auto, with same gigE settings - no connection. revert back to auto - no data.
Rebooting the 493G - data flows via eth.
It’s an uplink for two remote sites (what’s in a ring, so i even can ping the uplink, in case of no eth link).
I’m interested if there is any other option to solve this, than write a script, what checks the in/out counters for a while (like 5sec) and if so no change on any direction do a reboot?
493G was running with 5.18, now upgraded to 5.24 - fingers crossed.
