Hello.
I need to setup a 4G/wifi system for a boat, including a
- Wi-Fi external omnidirectional antenna with
- long range receiver with
- powered ethernet cable to a
- wifi router and 4g modem with
- external omnidirectional antenna.
It is meant to be used in coastal area or on moorings. Not on open sea. Therefore we have a satellite system.
The previous system I have to exchange was a metal jacket badboy with pepwave router.
This system was to difficult to operate for the owner.
Therefore I would need a transparent and easy to use system with as little involved components as possible for an easy maintenance by the owner but on the other hand a very powerful system to work under harsh and rough conditions.
Is there a chance to get such a solution with a microtic setup? Or does any one of you has an other proposition for realizing such a system?
Thanks in advance!
Virginia
