5.0 RC1 SSH crash again
I got again a SSH crash with 5.0 RC1 on RB750G.
This seems to produce randomly, after a few hours to a few days of uptime.
I’m using dude to probe the SSH service on this router.
I’m not alone to have this problem. From another thread in the forum :
"Confirm STILL bug in Beta 6 on RB-450G
got scared when I couldn’t log into remote site… luckily I have a tunnel that accepted a telnet session. …"
same problem in rb/600 & RB 411U
so, if you remove probe ssh does not crash?
I have seen ssh stop working a few times on a rb450g running 5.0 rc1.
This gets it running again:
/ ip service
disable ssh
enable ssh
The time before it fails, it prompts for passphrase, and even with the correct passphrase cut 'n pasted in, it fails. After that, no response on port 22 until I restart. Then ssh login works fine.
yes, that disable/enable stops (if working) and starts (if not working) ssh server. If after that it starts to work please make supout.rif file and send it to us, so we can fix the problem.
I have recently started having this issue on an x86 machine running 4.7. I upgraded it to 4.11 and ran into the same issue about 4 days later. Rebooting has fixed it, I will try disable/enable the ssh service if it happens again.
that is completely different issue as it is completely different peace of software (but it does same thing)
The same on rb333 with 5.0rc1. After some time the ssh server crashes/it’s impossible to connect to it.
Disable then enable helps for some time…
regards,
