5.0 x86 disable multi CPU and won't boot
System hangs at boot loader after updating to 5.0 beta and disabled SMP.
I downloaded the new netinstaller and it doesn’t see ROS on the 512MB CF card.
How can I get this up and running without losing my old key?
Ran netinstall, lost my key. Contacting support.
ROS 5 beta works pretty well, but disabling SMP is a big no-no.
Router went down April 22 after disabling SMP while testing 5.0 beta 1. I contacted support on the same day and I’ve been getting calls on this unit from the customer the entire time.
I need some help guys, making me pretty nervous about using beta software when support doesn’t help me get the box back up and going after the beta refuses to boot.
I finally convinced the local cable company to let me do the edge routing, and we’ve been waiting over 2 weeks for support to help me with the key after the beta crashed and netinstall didn’t save it.
