能检测到网卡,但无法使用。软件倒退了…
make supout.rif file and send to support. and please try to write in english.
He said the 5.0beta can find the intel 82559 nic but can not use it normal.
after changing anything it should work?
kamal
just upgrade to 5.0beta1 ,same here
ros can find that nic ,even you can config it to an ip address
but the nic just does NOT work(both in ip mode and mactelnet mode)
can’t connect to anything
maybe someting wrong with new nic driver?
4.6 worked and very stable
