5.19 for omnitik same as 433 baords?
Is the 5.19 package for 400 series boards the same as the omnitik package?
I ask because i installed the 400 series package onto an omnitik and it is starting to crash every 7 - 8 hours or so
the mipsbe or mipsl packages are generally always the same, so if its a mipsbe then its it will be the same, do you have any idea why its crashing, can you still telnet (mac-telnet) into it, does it do a watchdog reboot?
Thank for your answer I thought that was the case.
No idea yet as to why it is crashing.
watchdog is disabled. The router just freezes. all LED’s on solid. Router is not discoverable by any method.
Has 12MB of free memory 25MB of free HDD and CPU max usage 30%. Brand new unit. Firmware 2.41
I am going to set up a remote syslog to see if I can capture what is happening.
you running routing protocols on it?
disabling the watchdog is a overall bad idea?
Hi is there any solution for this reset issue or should we rather buy another type or router like a 443.
My omnitik network with radius has the same issues but my RB443 with radius network has no issues.
There is no solution for this problem. I have tried a 24VDC supply and adding more ram. The unit still keeps on resetting. In the end I had to add a RB751 to take over the radius server function. It is better and cheaper just buying a RB433.
