*) route - fix dst-prefix filtering did not return routes when routes with
different routing-mark were present;
*) wireless - improved nv2 stability;
*) winbox & webfig - added simple new version downloading & upgrading panel;
*) dhcp server - immediately store to disk changes for lease configuration;
*) lcd - improve graphs screen
*) lcd - improve touch screen (must /lcd reset-calibration)
*) smb - fix smb share mounting on linux systems
*) ovpn - fixed memory leak on disconnects;
*) userman - fix unpaid profile activation while authenticating;
*) sstp - fix high CPU usage on SSL handshake;
*) winbox - added ability to add time & date to dashboard;
*) metarouter - fixed lockups on RB110AH;
*) metarouter - fixed occasional lockups on RB450G;
*) ups - fixed problem connecting to USB device, introduced in 5.20;
*) quickset - added Wireless PTP Bridge mode;
*) fix MPLS MTU configuration usage;
*) dns - fix empty response;
It appears that this service is still not fixed. I now no longer show an available USB port.
I guess we’ll have to hope that this will be fixed in v5.22 or a future v6.x candidate.
Results for NV2 on the CPE side are not very encouraging (v5.20 AP):
Version 5.21: (82/20 value is CCQ)
Version 5.9:
EDIT: 5.9 with 3.41 firmware (from 5.21), had low CCQ as well, once “upgraded” to fw 3.38 CCQ improved.
EDIT2: keeping old firmware (3.38) I upgraded AP and CPE to 5.21 and CCQ came back to it’s normal values. Bandwidth tests show no degradation in throughput. So far so good…
What does it mean?:
I’m asking about it, because I have problems with MikroTik DNS long time. Maybe this fil will repair it, but what do You mean “empty response”??
What about the bug with IGMP proxy? Do you think will it ever be fixed??? Very frustrating and very unprofessional from Mikrotik! I wait for fix over one year!!!
your example proofs nothing. Low, or high, CCQ is also depending on traffic and wireless link conditions. I have links showing with all kinds of 5.x version very low CCQ but the moment I put traffic on them the CCQ goes up to near 100%.
So, unless you made more funded shortcomings examples in the wireless before to MT I am afraid they will not even consider to answer your tread here…
router with internet connection configured will connect to mikrotik.com and check if new version is available. If update is possible you have options to “download” or “download & upgrade” packages from the internet.
So if, you have just some routers around, you can in easy and fast way upgrade your router. if you have a lot of routers, better opt for some tool like TheDUDE to mange updates over the network.
