I have recently added a 5.8 backhaul and I am having very low bandwidth testing.
I have one 5.8 set to AP bridge with nstreme on and the other set to station pseudobridge with nstreme on.
The link is maybe 3-4 miles in distance.
If I do a udp bandwidth test I get around 2.5 Mbps on the Tx and anywhere from 1.0 kbps to 100 kbps on the Rx.
I have changed which unit is the master and slave with same results. I have also tested different frequencies with no major differences.
My other backhauls are set up like this and I normally get 20 Mbps to 32 Mbps on my bandwidth tests on them.
What ver. of ROS are you running. I had a few links that had same problem while running ver. 4.X, downgraded to 3.30 and everything has been running fine for a few months now. If you are running ver. 4.x try turning off nstreme.
