5.8ghz omni/dipole RM-SMA antenna advice
Hello I am planning a wireless network for a small hotel with the following setup:
-4x Basebox2 AP with 2x 2.4ghz dipole antenna (for clients) + 5.8ghz minipci-e card working as mesh or WDS (for AP inter communication).
I need a 5.8ghz omni antenna with rp-sma for outdoors, like the one who mikrotik sells (http://routerboard.com/ACOMNIRPSMA) but in 5.8ghz band.
Any recommendation? Mikrotik please sell this antennas! you are missing that!
Thank you in advice
Why use you a pigtail? something like that http://www.l-com.com/coaxial-rp-sma-plug-to-n-male-pigtail-2-ft-195-series
Found this antenna: http://www.ispsupplies.com/categories/5GHz-Omni-Antennas/RF-Elements-800-900MHz-Omni-Antenna_3.html
5.8ghz, outdoor ready, 5dBi, omni, works, inexpensive!!
