iam load balancing 5 adsl lines from different service provider and the problem is often page or browse is fail or address not found i don,t no how to solve this big problem i think problem in DNS setting
Force everyone to use your DNS cache on the router (2 DST-NAT rules for port 53 TCP and UDP) and point your Cache to ISP independent DNS server
hey >>>…<<<why no replies guys ??? I’am waiting your replies Experts
macgaiver has already answered, no?..
your post is like ‘something is broken in my house. how can I fix it?’ please, post detailed description of the problem, we’re not telepathists!
ok Thank you very much Chupaka but i need more explan and preferably with photo >>..thank you for attention
please read our posts ![]()
macgaiver mean that me add firewall nat rules
chubaka >…let me show you my setting in routeboard 493AH by photo and tell me what is new will doing or give me dst-nat script exactly
this is nat and mangle script
/ip firewall mangle
add action=mark-connection chain=input comment=“” disabled=no in-interface=
TEDATAsmh new-connection-mark=TEDATAsmh_conn passthrough=no
TEDATAeml new-connection-mark=TEDATAeml_conn passthrough=no
EGYNEThm new-connection-mark=EGYNEThm_conn passthrough=no
EGYNETngy new-connection-mark=EGYNETngy_conn passthrough=no
EGYNETrm new-connection-mark=EGYNETrm_conn passthrough=no
add action=mark-routing chain=output comment=“” connection-mark=
TEDATAsmh_conn disabled=no new-routing-mark=TEDATAsmh passthrough=yes
TEDATAeml_conn disabled=no new-routing-mark=TEDATAeml passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=EGYNEThm_conn
disabled=no new-routing-mark=EGYNEThm passthrough=yes
EGYNETngy_conn disabled=no new-routing-mark=EGYNETngy passthrough=yes
add action=mark-routing chain=output comment=“” connection-mark=EGYNETrm_conn
disabled=no new-routing-mark=EGYNETrm passthrough=yes
add action=mark-connection chain=prerouting comment=“” disabled=no
in-interface=3EBOOR new-connection-mark=TEDATAsmh_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:5/0
in-interface=3EBOOR new-connection-mark=TEDATAeml_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:5/1
in-interface=3EBOOR new-connection-mark=EGYNEThm_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:5/2
in-interface=3EBOOR new-connection-mark=EGYNETngy_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:5/3
in-interface=3EBOOR new-connection-mark=EGYNETrm_conn passthrough=yes
per-connection-classifier=both-addresses-and-ports:5/4
add action=mark-routing chain=prerouting comment=“” connection-mark=
TEDATAsmh_conn disabled=no in-interface=3EBOOR new-routing-mark=TEDATAsmh
passthrough=no
TEDATAeml_conn disabled=no in-interface=3EBOOR new-routing-mark=TEDATAeml
passthrough=no
EGYNEThm_conn disabled=no in-interface=3EBOOR new-routing-mark=EGYNEThm
passthrough=no
EGYNETngy_conn disabled=no in-interface=3EBOOR new-routing-mark=EGYNETngy
passthrough=no
EGYNETrm_conn disabled=no in-interface=3EBOOR new-routing-mark=EGYNETrm
passthrough=no
add action=masquerade chain=srcnat comment=“” disabled=no out-interface=
TEDATAsmh
TEDATAeml
EGYNEThm
add action=masquerade chain=srcnat comment=“” disabled=yes out-interface=
3EBOOR
EGYNETngy
EGYNETrm
this is Complete photo
why no posts guys
hey no one reply me … why???
not shore whats the problem lots of pics but not much information on the problem
can you ping that address at that moment?
the ping is very good but some times browse is fail .. like( when you open http://www.yahoo.com it’s work good and when open games in yahoo Possible work, or do not work as possible ) and other some times working good >… i hope you get me … sorry for my english
I would suggest to simplify your environment and start testing. Keep just 1 DSL and disable the rules and packet marks for the rest. Test that everything is ok. Then add a second DSL, enable it’s rules, etc. Test again. Add a third one, test… and so on.
It’s very important to have a good set of tests which should emulate what your users will do.
Good luck!
