Dear All.
I Have two RouterBoard Outdoor, with diferent version of RouterOS
Box-1 2.8.26
1 name=“athz1” mtu=1500 mac-address=00:01:24:70:54:12 arp=enabled disable-running-check=no interface-type=Atheros AR5211 radio-name=“000124705412”
mode=ap-bridge ssid=“arput02” frequency=5130 band=5ghz scan-list=default-ism rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled fast-frames=no dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes
default-forwarding=yes hide-ssid=no 802.1x-mode=none disconnect-timeout=3s on-fail-retry-time=100ms
Box-2 2.8.23
0 name=“internet” mtu=1500 mac-address=00:01:24:70:54:0E arp=enabled disable-running-check=no interface-type=Atheros AR5211 radio-name=“SA-ARPUT”
mode=station ssid=“arput02” frequency=5130 band=5ghz scan-list=default-ism rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
Is my configuration OK ?
If so .. why I don’t see any connection between the …
I plug the antenna and both system are in the same room.
And , I tried to update the BOX-2 to 2.8.26.
Upload the new (2.8.26 RouterOS)..
The upload looks fine .. the files was there before I reboot
Reboot, and check the “packages” … and I found it’s still 2.8.23.
Sincerely
-bino-
