5 GHz Link Failures / Trace possible?
The last two days, two of my P2P-Links went down. Signalstrength used to be about -75 dbm. Suddenly, signalstrengh continuously got more worse.
  • 1 hour later: 82 dbm
  • 2 hours later: 88 dbm
  • 3 hours later: 92 dbm
  • 4 hours later: no link.
One day before, we had a big thunder-storm. Therefore I thought that some routerboards were damaged. I changed the hardware of one p2p link, but no success. I checked cable and antennas, but I could not find any failure. Therefore I changed hardware back to the old one.
24 hours after the link went down (6 hours after I finished my checks), both links went up again with -75 dbm. No hardware damaged.
Is it possible, that atmospherics caused this error? I would like to make a wlan-trace or something else. Is this possible with Mikrotik-OS? I could not find a similar option.
Is it also possible, to watch the noise-level with Mikrotik OS? Only thing I always see, is signal-strenth, but no noise-level.
Thank you in advance.
Stefan.
Meanwhile, I heard from two further 5 GHz P2P-projects (all in germany), having the same problem in the last 48 hours.
On of them, using Lancom-components, upgrated his firmware to solve this problem. The new firmware is optimized for radar problems.
Is there anybody else, observing simliar probles with his p2p-links in the last 48 hours?
