I’m sitting with a back haul high site that must also do 360 degree coverage. Thus, 2 x backhaul wireless cards and 3 x AP wireless cards. Running XR5’s. I’m tempted to do this setup with a RB600 and a daughterboard. More than enough space for the cards, but will the power supply be adequate? If this is not going to work, I’ll have to do 3 x RB433AH’s? Getting expensive…
RB433’s can only take 2 XR5’s and when mounting equipment 50-100m up on a tower it gets expensive to run power cable up there. Using an RB600, logistically, is just so much easier and cleaner… maybe I’ll try to run 4 x XR5’s and 1 R52H. What kind of power supply would I need to run something like this?
Its not a problem to fit the cards. You’ll be able to fit 6 XR5’s. The problem is the power supply… I think a maximum of 4 XR5’s will be safe? What do you think…?
