$50 for Router Setup and Configuration Guide
Hello, everyone!
I will pay (with help of PayPal) $50 to the person who firsts will solve my problem and explained how s/he has done it. If everything will work as it should we shall upload this guide to Mikrotik wiki.
I have RB750GL router, but I don’t know much about networking.
I would like to utilize multi-wan load-balancing method with PCC. (I need to know how to do it for 2 WAN and 3 WAN connections to two different ISP)
I need you to set all necessary configuration (NAT, Firewall, etc.) for my router to function as best as possible.
I would like you to explain how to set two LAN connections with 2 separate subnets as well as how set them under one subnet.
First Ethernet port will be used for POE.
I need to know how to configure mac filtering on LAN side of the router(my router will be located outside of my flat, so I don’t would my neighbor to steal my internet connection).
Should we use DMZ?
The most important thing is that I would like you to teach me how you done this configuration.
Extra information: Multi-WAN load-balancing method with PCC.
I found a reference to “Using PCC to load balance across multiple non bonded links.” (source: http://www.mikrotik-routeros.com/?p=12#more-12)
I don’t know what does “non bonded links” mean. Should I use PCC load balancing with bounded links?
Thanks you for your help.
non-bonded - means you have several links but they work as separate connections. And all the balancing is done on one router. PCC you need because of IPv4 NAT problem - to make connections persist on the link they where created on. Very important for ssl/tls sessions.
You can look up one end of the bargain how to configure ppc on 2 links, addition of 3rd is comparably easy if you understand how 2 links work.
Other end is, if at all that can be called that way - is PPPoE server for LAN1 and static/dynamic config for LAN2 that should be straight forward from manual.
If I understand you correctly non-bonded links only mean three separate connections to the Internet. Please correct me if I’m wrong.
My goal is to combine them into one connection and increase the overall speed of the Internet.
Can I use the omega-00 configuration “Using PCC to load balance across multiple non bonded links” http://www.mikrotik-routeros.com/?p=12, to achieve the highr internet speed?
yes. that is correct. That is example you should follow.
However you will get near maximum output through these lines. As max is only available if you are using bonding, but for that you have to control both ends of the link.
Why do I need PPPoE-server?
Can you tell me how to make eth1-master, eth2-slave switch?
I know it should be easy, but then you do not know to do it, it seems very hard.
Eth1 will connect to an unmanaged switch in apartment number 1
Eth2 will be connected to a wireless router in the apartment number 2
You mean the other end of my internet line (end of the cable which goes to ISP)?
I gotta admit that I’m a little bit confused
i misinterpreted your POE as PPPOE, if you do not need that, then you do not need that server.
under ‘/interface ethernet’ you can set one port as salve port of other one by setting master-port.
when you fill master-port field you will make this port a slave port of one you set in master-port field. you will only see traffic in router that is going through the router not through switched ports.
edit: for bonding you have to control both ends (your and ISP in this case) so you have to use load balancing - example you pointed to.
I really appreciate your help.
Sorry for my ignorance, but I do not know how to create the switch.
I read that I should create a bridge, and then add for each Ethernet port to the bridge.
But I am lost from here.
In the example below, only one LAN port is used.
What should be changed to use this configuration for both ports Ethernet?
“dst-address-type=!local in-interface=LAN new-connection-mark=wan1_pcc_conn passthrough=yes per-connection-classifier=both-addresses:3/0”
in your case, if you set for ether2 attribute master-port=ether1 then these 2 ports will be swtiched. Traffic that go between the ports will be be visible by the router.
So, if I leave the LAN1 in configuration example below, will it work for both LAN ports?
yes, if ports are switched, then only master port have configuration in RouterOS. SO if you set ether2 master-port=ether1 and assign IP address on ether1, then both ports will have that. Traffic from either of ports will count as ether1 traffic (f that goes through the router or to router)
What about firewall?
Can I use script from wiki? NetworkPro on firewalling http://wiki.mikrotik.com/wiki/NetworkPro_on_firewalling
What should i change there?
btw, You are the man! :smiley:
no, not directly, he is using routed network, with switching set up you are using bridged. You can look through firewall examples and adopt good ideas.
[removing post]
Actually I’m far from setting firewall rules.
Could you explain how to link WAN1-pptp interface to WAN1 and WAN2-potp to WAN2 so on.
How should I configure NAT?
What other things should I think about?
I didn’t have time to copy your firewall example. Could you post it again?
It’s in your other thread. It’s part of the tutorial I posted. That’s pretty much all I can contribute to your request for detailed explanations.
Fewi’s setup guide linked above is very extensive and effectively a CLI tutorial. There are also quite a number of other setup guides and even wizard type setup scripts on the wiki. For example: http://wiki.mikrotik.com/wiki/A_script_to_set_up_WAN/LAN/WLAN_to_get_you_started
Are you talking about this post?
Thank you, but first i need to unbrick my router.
