50 meter RJ45 cat6 cable
I would be very happy if any body can tell me why Ehternet1 is unstable when I use 50m cat6 cable.
I tried to access MT532 via wireless - it is working from near side my tower. however - I faild to make a point to point bride from 8km distance. I am using Senio CPE, I can see signal strength 75. However, I can not ping my MT box. I fixed TX power 24db - as I am using 400 mW miniPCI card. I had also fixed all basic data rate.
please write your config…without it we can`t help to find mistake…
0 R name=“Kelly2Mbabane” mtu=1500 mac-address=00:02:6F:40:75:10 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name=“00026F407510” mode=ap-bridge ssid=“Kelly2Mbabane” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=24
frequency=2417 band=2.4ghz-b/g scan-list=default rate-set=configured
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps max-station-count=2007
ack-timeout=66 tx-power=22 tx-power-mode=card-rates
noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no
1 R name=“Kelly2Oshoek” mtu=1500 mac-address=00:02:6F:40:75:22 arp=enabled
radio-name=“00:02:6F:40:75:22” mode=ap-bridge ssid=“Kelly2Oshoek”
area=“” frequency-mode=manual-txpower country=no_country_set
antenna-gain=24 frequency=2437 band=2.4ghz-b/g scan-list=default
rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
ack-timeout=135 tx-power=24 tx-power-mode=all-rates-fixed
Are you familiar with the standards for installation and wiring?
What is it connected to? at what ethernet settings?
And finally, how do you define “unstable” ?
I don’t see how this has anything to do with ether1…
PTP bridge with senio cpe? is that using wds or is it “mac-nat”?
fixed all rates, uhm, perhaps put it back to default for testing?
I am not using WDS or mac-nat. It is ap-bride and station mode. I am just testing my network. I may make a bridge and station mode in MT boxes.
I am planning to make a 30km bridge in two hops. the first hop I am planning to use 5.8Ghz where the distance is 5 km. I am using 13km link using 2.3Ghz and rest 5.8 Ghz. I am using two repeater site. each of them I am using MT532 and both end I am using MT112. I dropped the plan to use Senao as it is changing the channel frequently.
However, Still I can see too much unstability in my first link. ping time is over 100ms to 500 ms. It was default initially. I wounder how I can get optimum performance. I have seen some response in this forum to fix the data rate and Tx power.
Another problem I am facing is aligning antenas. Does any body tell me the strategies for aligning Antenas using Mikrotik?
And how does this relate to subject?
Sorry,
My problem was sorted.. and i am looking at different dimensions now. If you can assist me without looking at subject, i would be very happy
nei
