Hello!
I have set up VPN server on my mikrotik.
Local network and VPN network have same network 192.168.101.0/24
I want to have access from VPN clients to local network.
From VPN client I can ping mikrotik - OK
But when I ping from VPN client any device in local network - 50%-100% of packets are lost.
Please, help me.
Why packets are lost? Thank you in advance.
Config:
# apr/29/2022 13:39:54 by RouterOS 6.49.6
# software id = AH0R-01NU
# model = RB952Ui-5ac2nD
# serial number = F0DB0E67D186
/interface l2tp-server
add name=l2tp-xxx user=xxx
add admin-mac=2C:C8:1B:8D:9B:8C arp=proxy-arp auto-mac=no comment=defconf \
name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=russia disabled=no distance=indoors frequency=auto installation=\
indoor mode=ap-bridge ssid=xxx wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=russia disabled=no distance=indoors frequency=\
auto installation=indoor mode=ap-bridge ssid=xxx wireless-protocol=\
802.11
/interface vlan
add arp=proxy-arp interface=ether2 name=vlan1 vlan-id=1000
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=xxx \
wpa2-pre-shared-key=xxx
/ip ipsec profile
set [ find default=yes ] dh-group=ecp256,ecp384,modp2048,modp1024 \
enc-algorithm=aes-256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
aes-256-cbc,aes-256-ctr
add name=dhcp ranges=192.168.101.30-192.168.101.254
add name=vpn ranges=192.168.101.10-192.168.101.29
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add bridge=bridge change-tcp-mss=no local-address=192.168.101.3 name=\
"xxx vpn" remote-address=vpn use-compression=no use-encryption=no \
use-mpls=no
set *FFFFFFFE local-address=192.168.101.1 remote-address=vpn use-encryption=\
required
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=vlan1
/interface l2tp-server server
set authentication=mschap2 default-profile="xxx vpn" enabled=yes \
ipsec-secret=xxx use-ipsec=yes
/interface pptp-server server
add address=192.168.101.1/24 comment=defconf interface=vlan1 network=\
192.168.101.0
add address=91.143.xxx.xxx/22 interface=ether1 network=91.143.xxx.0
add address=192.168.100.1/24 interface=ether2 network=192.168.100.0
add address=192.168.101.3/24 interface=bridge network=192.168.101.0
/ip dhcp-client
add address=192.168.101.0/24 comment=defconf dns-server=192.168.101.1 \
gateway=192.168.101.1 netmask=24 ntp-server=192.168.101.1
set allow-remote-requests=yes servers=\
8.8.8.8,4.2.2.2
/ip dns static
add address=192.168.101.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.101.0/24 list="Local Nets"
add address=192.168.100.0/24 list="Local Nets"
established,related,untracked
invalid
add action=accept chain=input comment="NTP Server" dst-port=123 in-interface=\
bridge protocol=udp
add action=accept chain=input comment=VPN dst-port=1723 in-interface=ether1 \
protocol=tcp
add action=accept chain=input comment=IPSec in-interface=ether1 protocol=\
ipsec-esp
add action=accept chain=input comment=IPSec dst-port=500,4500,1701 \
in-interface=ether1 protocol=udp
in-interface-list=WAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat disabled=yes dst-address=!192.168.201.0/24 \
src-address=192.168.201.0/24
add action=masquerade chain=srcnat dst-address-list="!Local Nets" \
out-interface-list=WAN
add distance=1 gateway=91.143.xxx.xxx
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
add disabled=yes interface=ether4 type=internal
/ppp l2tp-secret
add
/ppp secret
add name=xxx password=xxx profile="xxx vpn" service=l2tp
/system clock
set time-zone-name=Europe/Moscow
/system logging
add topics=l2tp,!debug
/system ntp client
set enabled=yes primary-ntp=132.163.97.1 secondary-ntp=188.225.9.167
/system ntp server
set enabled=yes multicast=yes
/tool mac-server
/tool mac-server mac-winbox
