5500 to 5700 Mhz Range doesnt seem towork properly
Good day,
For me it is very important to use the 5500 to 5700 mhz frequency range in order to avoid interferences beacuse 5180-5320 and 5700-5835 are pretty congested in my country. Thing is it has been happening a lot to me that after running some freq scans in which the conclusion is that there are plenty of clean spots to place my links within this range, they dont really work well and behave as if there were lots of interference, i get good rssi and radios are aligned properly but my response times and link stability in general are horrible, so im beggining to think im missing something regarding this frequency range… Does anyone know what might be happening here?
Thx in advanced.
what exactly is the problem when using this range? disconnections or what? did you try snooper/frequency monitor/spectral scanner in RouterOS to see these ranges?
The problem is the links behave as if there were heavy interferences, bad ping times, lost packages, bad results on bandwidth tests, but when we run Freq Scan and freq Usage tools we dont see any signals that should be causing this behavior.
does your antenna work in this freq? do you have doppler radar near by?
Yes our antenna work on the 4.9-5.9 Ghz Range.
And im not sure there is a doppler radar arround, is there any way to check that?
