Did someone tried 5 GHz Antenna Feed with normal Fiber Glass which used for Sat TV CH. because importing more then 10 dBi antenna in our country is prohibited.
Can we use this dish with the feed.
The Dish is the same . The Dish in the picture will serve good as long as you match the offset position of the Dish and the feeder.
I will vote that the such parabolic dish are much more good than regular grid’s because of high accuracy in reflecting the beam.
