5GHz-a/n question (mixed mode AP)
I would like to have some things clarified about mixed 802.11A and 802.11N mode environment.
I have read some papers which discuss compatibility between A and N mode and it looks for me that the Mikrotik box configured into 5Ghz-a/n should be in so called “Mixed mode”. Thus it is sending an extra header which is used by A mode clients to see that there is a packet being transmitted in unknown protocol and N mode client will know from the header that it should expect a packet in an N modulation scheme. So both A/N mode AP and client will send the extra header. Is it true? And will the station in A/N mode send the header even if the AP doesn’t support the N mode?
Since not all of our clients stations are equipped with N card yet I am considering the option to switch the clients to A/N. I am not sure if the advantage of higher modulation will not be overruled by larger overhead or so. Any suggestions, experiences?
It’s possible that you might find something if you were to use IPerf and test all the different possible combinations -
That being said…we have several APs configured this way in both the 2.4 and 5ghz and haven’t noticed a drop in performance for the N clients. I think as along as you’ve got good signals (better than -75) you should be in great shape.
Hope that helps!
