Hi all,
there are antennas like this? ¿5GHz and 90º@19dBi sector?
Can you say me the brand and the model?
Thanks,
Hi all,
Thanks,
Try this one, it works very well:
17 dBi 90 Deg 4.9-5.8GHz VPol Sectorial SA4958-90-17 made by Pacific Wireless (Pac Wireless) They also make one that is: SA4958-120-16 and is also a very good one.
Yes, I know, but I need to confirm that there isn’t any sector of 90 degrees with 19 dBi.
There is a public municipality here that needs a project with this 19 dBi antenna, but I think that this not exists..
ya, you are right…
most sectorial is max with 17dbi antenna
I checked thru Hyperlink (L-Com) Catalogue at a time, what they had is 5.8GHz 17dBi 90 degree sector antenna (I dont know of now) but they had 2.4GHz 20dBi 90 degree sector antenna as at then. Meanwhile, Pacific has 5GHz 19 dbi Integrated antenna and they still work fine for long range.
yes, but this pacific 19dBi is not a sector antena.
It is not a sector antenna but It’s also a directional antenna. It is called Patch panel antenna- in my own case I opted for integrated one that allowed me to insert my radio inside the antenna thereby getting rid of antenna cables and the rest. It is has 16degree H & V beamangle. very low wind loading… May nt be suitable for at the base for Ptmp but suitable as a station.
