While I just read the Mikrotik definition of OSPF and I have been aware of the concept but have not had any practle experance with it. I’m use to bridging, routing, and setting up radius,ppoe clients.
Could you give an example of how to setup such a connection?
Lets say you have four stations, starting with 192.168.1.1 to .5
Each of the units having both 802.11a card for backbone relay and a 11b card for clients.
.1 being the starting system that is connected to your land line connection through ethernet.
.2 being a mountain top
.3 beign able to see both the mountain top .2 system and .1 system.
.4 only being able to see .2
.5 only seeing .4
This would be a very good real life example that I think many others that currently use wds would like to see an alternitive way of doing such a setup.
It is a simple solution that works well. USing your example
192.168.1.1 MT I assume is the core router. under /ip/routing/ospf set this router’s ID to 10.10.10.1 and distribute as type one and redistribute default route. Create an area of 0.0.0.0
then go to .2 and set up an ID of 10.10.10.2 and place this router in the area 0.0.0.0. Redistribute as type 1 but DONOT redestribute default routes.
do the same for the other routers. Make sure to reboot core then each neighbor in logical order and watch the dynamic routing work.
As far as limiting visibility within your your network, that would be another discussion.
Why is it important to reboot routers in order? Surely the OSPF will sort its self out, using 192.168.1.1 (10.10.10.1) as the default route for the whole network?
