5Ghz Bridging Problem
I have a bridging setup on 5 Ghz. The AP has MT 2.7.20 and the remote end has MT 2.8.10. The WLAN interfaces are on EOIP on private IPs. Now my problem is that the bridging link keeps going out every 1 to 2 hours and I can’t ping any of the other devices on the other side. When I check the AP site on the Wireless Registration Table, I can’t see the other remote box connected to it. What could be the problem. Do you think there is some bug on the BASE MT 2.7.20 that I’m using.
Thanks,
Hemanta
I suggest that the other side have 2.8 also (current is best - 2.8.11).
John
