5GHz Channel
I’ve set my 2.4GHz radio to a fixed 20MHz channel but my 5GHz radio is currently selected to automatic frequency.
My understanding of the permitted 5GHz uses is based on https://www.cablefree.net/wirelesstechnology/unlicensed-wireless-links/using-the-5ghz-band-in-the-uk
It seems to be consistently choosing channel 46 - 5240/20-eeeC/ac/P(17dBm) after every reboot, which suggests it is not making use of channels where DFS can be used with greater transmit power. My understanding of the function of DFS is that it should be scanning channels prior to enabling the radio. It appears at the same time as the 2.4GHz radio on a fixed allocation, so I don’t believe this is occurring.
See relevant config below, I have re-named the real SSID names to the VLAN name. I am not using the “Management” SSID on the physical interface and I am thinking I should move one of the virtual interfaces onto this instead.
Regulatory domain forces a minimum antenna gain of 3 however I understand this hardware is actually 2.5 (although it’s not possible to set a decimal place)
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-b/g/n country=\
    "united kingdom" disabled=no frequency=2462 frequency-mode=regulatory-domain \
    hide-ssid=yes installation=indoor mode=ap-bridge name=2.4GHz radio-name=\
    Management ssid=Management wireless-protocol=802.11 wps-mode=disabled
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys name=\
    5201_WPA2 supplicant-identity=""
    GUEST_WPA2 supplicant-identity=""
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=\
    static-keys-required name=5201_WEP static-algo-1=104bit-wep \
    static-transmit-key=key-1 supplicant-identity=""
/interface wireless
set [ find default-name=wlan2 ] antenna-gain=3 band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country="united kingdom" disabled=no frequency=auto \
    frequency-mode=regulatory-domain hide-ssid=yes installation=indoor mode=\
    ap-bridge name=5GHz radio-name=Management security-profile=5201_WPA2 ssid=\
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=\
    76:4D:28:8E:75:4B master-interface=2.4GHz multicast-buffering=disabled name=\
    VLAN40_2.4G security-profile=5201_WPA2 ssid=VLAN40 vlan-id=40 \
    vlan-mode=use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
    76:4D:28:8E:75:4C master-interface=5GHz multicast-buffering=disabled name=\
    VLAN40_5G security-profile=5201_WPA2 ssid=VLAN40 vlan-id=40 \
    76:4D:28:8E:75:49 master-interface=2.4GHz multicast-buffering=disabled name=\
   VLAN20_2.4G security-profile=5201_WEP ssid=VLAN20 vlan-id=20 vlan-mode=\
    76:4D:28:8E:75:4A master-interface=5GHz multicast-buffering=disabled name=\
    VLAN20_5G security-profile=5201_WEP ssid=VLAN20 vlan-id=20 vlan-mode=\
add disabled=no keepalive-frames=disabled mac-address=76:4D:28:8E:75:4F \
    master-interface=2.4GHz multicast-buffering=disabled name=VLAN80_2.4G \
    security-profile=GUEST_WPA2 ssid=VLAN80 vlan-id=80 vlan-mode=use-tag \
add disabled=no keepalive-frames=disabled mac-address=76:4D:28:8E:75:50 \
    master-interface=5GHz multicast-buffering=disabled name=ORAM-GUEST_5G \
    76:4D:28:8E:75:4D master-interface=2.4GHz multicast-buffering=disabled name=\
    VLAN60_2.4G security-profile=5201_WPA2 ssid=VLAN60 vlan-id=60 \
    76:4D:28:8E:75:4E master-interface=5GHz multicast-buffering=disabled name=\
    VLAN60_5G security-profile=5201_WPA2 ssid=VLAN60 vlan-id=60 \
    76:4D:28:8E:75:47 master-interface=2.4GHz multicast-buffering=disabled name=\
    VLAN10_2.4G security-profile=5201_WPA2 ssid=VLAN10 vlan-id=10 vlan-mode=\
    76:4D:28:8E:75:48 master-interface=5GHz multicast-buffering=disabled name=\
    VLAN10_5G security-profile=5201_WPA2 ssid=VLAN10 vlan-id=10 vlan-mode=\
I’ve manually set a channel for now.
