I’ve got a pretty strange issue here with a point to point link. Total link distance is about 20km, with good Fresnel (about a 0.8F1 if I recall what RMD said).
On the A end I’ve got an RB532 with an SR5 and XR5. The XR5 is this link, the SR5 is another point-to-point link that is working fine. The unit is powered by a 48v 500mA PS with appx 75ft cat5 cable. Antenna cable is RG8/U about 6ft long, antenna is Pac wireless GD58-29
On the Z end I’ve got an RB133 with XR5 for this link, R52H in 2.4Ghz-B mode for p2mp, and an R52 running another 5.3Ghz point to point link which is operating fine. Power supply is 18v 900mA. Antenna cable is RG8/U about 12ft, antenna is pac wireless GD5W-28.
When first configured signal strength on this link was -68 with a noise floor of -104, and it worked fine for about three days. Original configuration was for 5Ghz standard channel size, frequency 5785Mhz, nstream off, WPA/2 enabled.
After about three days, the link started flapping, and has kept doing so for about a week. I’ve tried every channel (even those with other equipment on them) including the “low band” 5.1-5.3Ghz and moving to 10Mhz channel spacing. I’ve also tried enabling nstream (wouldn’t stay associated for more than 4-5 seconds), and disabling WPA (no effect).
In all cases that it would even associate for 5.1-5.3Ghz band signal was about -78 (out of tune for one end), on all hi-band (5.7GHz+) channels that would associate signal is -70 to -75 with SNR between 20 and 30dB. CCQ didn’t strike me as good, but when it’s up I can do 8Mbps TCP bi-directional through the link (aggregate). On 10Mhz channels, I had much more difficulty getting an association. Very few channels work, and it won’t stay up for even a few seconds.
Despite all of that, the link keeps flapping even though the signal is perfectly workable (several other links with the same A location have less signal and have been working flawlessly for months to years).
Any thoughts or suggestions? I’m not sure what’s wrong with this situation. The SNR is great (20-30dB), when the link is up signal is excellent and throughput is quite acceptable. Generally it will stay up through daylight hours, then flap at night - though as I write this the link is down at 12:30pm CST.
