Hello everyone.
I have a rb951ui-2nd, but I wanna 5GHZ.
Should I buy a Rb952ui-5ac2nD or maybe some PoE AP with 5ghz only, to attach to my rb951ui-2nd.
No idea on what should I do.
Any help is appreciated.
Merry xmas !!
Hello everyone.
Merry xmas !!
Yes, you may attach PoE AP with 5GHz
Sent from my iPhone using Tapatalk
Nice to know, thanks.
You think it would be better to attach that or to just buy a Rb952ui-5ac2nD?
Also, can you please recommend a good PoE AP ?
The main measure is: Better for what?
good point.
Price, quality of service, hassle of getting it operational.
If one device is enough, get rb962 instead, because it has triple chain radios. If just any 5ghz is enough, get the rb952. If you need sector ap, look at Sxt models with level 4 license.
I see, I think the 952 fits better. Thank you for your advice!!!
