Hey there
I was setting up hap ax2 ap and i have no problem connecting to the 2.5 ghz wifi but no matter what i do the 5ghz channel doesn’t work and it won’t even show up on any of the devices i have
I tried setting the band on A/N and channel width on 20/40 mhz ce but nothing
What should i do ?
First start with exporting your configuration. Also did maybe the problem is that you are using DFS channel so router scans for nearby radars for a few minutes.
If no radar is detected then 5GHz radio is turned on.
Can go up to 15 minutes…
