Does anyone know why that when you set an AP to 5mhz channels, and then scan that AP from another unit, it shows more than one listing for that radio/ssid? It will show the same ssid, with multiple entries, each at a different 5mhz frequency, usually about 10 or 20mhz higher in steps. Most of the time it shows three total for each radio/ssid, other times it is 2 or 4 though. What gives?
SMA
No one else has this happening to them?
SMA
Just a guess:
Since a normal channel is 22MHz the discovery from a normal AP or sniffer gets confused… I’ve had this happen when playing with tight analog filters.
Mike
