[6.0, 6.1, 6.2] Bug in Reset Configuration permissions
I’m trying to reset configuration (with “keep-users”) as a user with all perms but “policy”. I get an error:
/system reset-configuration keep-users=yes
Dangerous! Reset anyway? [y/N]:
y
system configuration will be reset
not enough permissions (9)
/user group print
3 name=“name” policy=local,telnet,ssh,ftp,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,!policy
“policy” is permission to change user configuration. “keep-users” parameter means “don’t change user configuration”. As a result “/system reset-configuration keep-users=yes” should be allowed without “policy” permission.
i have not seen the error you reported when i log on using winbox using the admin account and start a terminal session to enter the commands. i suspect that the admin account may have the ‘policy’ ploicy.
However, if i do try the reset command with a request to run an x.rsc file after reset
/system reset-configuration keep-users=yes skip-backup=yes no-defaults=yes run-after-reset=xxxxxx.rsc
where the file xxxxxx.rsc exists in the file list.
The configuration is successfully reset but the file is not run after restart. Unless i am missing some other prerequisite, this seems to not have worked in any of the 6.x releases so far.
Have you successfully tried to use the run-after-reset command? Is there some other requirement outside of an existing file?
cieplik206,
run-after-reset works well. I had problems with it until I looked at default MT script, it starts with:
:while ([/interface ethernet find] = “”) do={:delay 1s;}
This means: wait for any ethernet interface
If you don’t wait you may execute a command that fails due to no interfaces recognized. Failing one command stops executing the script.
Yes, admin account has all perms.
In 6.5 I still can’t do “/system reset-configuration keep-users=yes” as a user with all perms but “policy”.
