6.13 and simple queues?
Is there a issue with simple queues on 6.13?
[cknipe@AMS-CN01-CR01] > /queue simple print stats interval=1
 1    name="test" target=41.79.165.241/32 rate=0bps/0bps total-rate=0bps packet-rate=0/0 total-packet-rate=0 queued-bytes=0/0
      total-queued-bytes=0 queued-packets=0/0 total-queued-packets=0 bytes=0/0 total-bytes=0 packets=0/0 total-packets=0
      dropped=0/0 total-dropped=0
There’s PILES of traffic matching that IP address.
However, using interfaces in the target, it works fine
 1    ;;; x
      name="x" target=x01,x02,x03,x04 rate=98.8Mbps/2.2Mbps total-rate=101.0Mbps
      packet-rate=8483/5521 total-packet-rate=14005 queued-bytes=0/0 total-queued-bytes=0 queued-packets=0/0
      total-queued-packets=0 bytes=1112035400889/23697822622 total-bytes=1135425236459 packets=766982008/469570498
      total-packets=1236256592 dropped=269837/28101 total-dropped=134442
Hi Chris,
did you see this? v6.13 released!
Skimmed through it, mailed support, and busy downgrading to 6.10 6&@$^&@$&^%&@#$^&*^#$
Why oh why, can’t we just get a release that works! :frowning:
To much to do for them I really think!
CCR Series, a bunch of new devices, Caps manager and so on and so on…
SwitchOS and TheDUDE are sleeping, but I think if this orgie is flat they would
be abble to serve as the good all times. I hope so.
hi,
sorry for posting on this subjet.
i’m looking for savage.
I want to know if u have found a solution for your contention problem. I have the same problem, and i’m still looking for a solution.
Thx in advance.
Under the Link in my first post you will find something like this!
Is this helping you out!?
What's new in 6.14rc10 (2014-May-26 14:52):
*) fixed - simple queues could sometimes crash router;
*) fixed - simple queue stats freeze (empty winbox queue window);
Sorry,
my real problem is how to do dynamic contention with mikrotik.
