[6.17] local variables only lowercase allowed?
Are in local variables only lowercase characters allowed?
I have a strange behaviour within a script.
:local LtgGefunden false;
:set LtgGefunden true;
:if (LtgGefunden = true) do={
	:log info "correct behaviour";
	} else={
	:log info "oops thats wrong"
The behaviour of the script depends on the characters
of the local variable. If there is an uppercase character
in the name of the variable the IF condition fails.
:local LtgGefunden => IF condition fails
:local ltgGefunden => IF condition fails
:local ltggeFunden => IF condition fails
:local ltggefunden => IF condition works
I checked the value of the variable before the IF condition and the value is always equal true.
I use 6.17 on a RB2011 and CCR-1016.
Any idea what´s going wrong here?
FIrst of all, you must write correct syntax, is near all wrong:
:local LtgGefunden value=false;
:set $LtgGefunden value=true;
:if ($LtgGefunden = true) do={
:log info message=“correct behaviour”;
} else={
:log info message=“oops thats wrong”;
Hi rextended
it´s the syntax written on the wiki page: http://wiki.mikrotik.com/wiki/Manual:Scripting
Examples:
:global a; :set a true;
:log info “Hello from script”;
But you are right, there is an syntax error in the IF condition I didn´t notice.
The $ was missing. With $ script works.
Thanks.
value= and message= is not necessary $ in set command is not necessary
$ was missing in this line :if ($LtgGefunden = true) do={
On RouterOS 6.7:
[admin@Gateway] > :set x value=3;
expected variable name (line 1 column 6)
[admin@Gateway] > :global x value=3;
[admin@Gateway] > :set $x value=3;
On RouterOS 6.18:
[admin@MATRIX] > :set x value=2;
syntax error (line 1 column 6)
[admin@MATRIX] > :global x value=1;
[admin@MATRIX] > :put $x;
2
[admin@MATRIX] > :set $x value=3; <<<<< now this instruction do not do error. On 6.7 yes.
3
[admin@MATRIX] >
:set has this command line:
:set name= value=
I’m expecting:
:global varname value=test;
:global test value=0;
:set test value=7;
At this point I’m expecting test = 7, and is.
But if I write:
:set $varname value=666;
I’m expecting at this point, set the variable named with the name inside varname to 666:
varname=test
test=666
But… is not.
Is this:
varname=666
test=7
Nested variables are not supported in RouterOS.
v6.18 just has more relaxed syntax. :set x 3 is the same as :set $x 3
What you could do is make an array and then access array elements by keys.
:global a;
:set ($a->“x”) 1;
:set ($a->“y”) 2;
:put ($a->“x”);
Thanks for the detailed reply :wink:
