[6.18] no-ip script nat
can u help me the script wont work on v6.18…
# No-IP automatic Dynamic DNS update for RouterOS v6.x
#--------------- Change Values in this section to match your setup ------------------
# No-IP User account info
:local noipuser "USERNAME"
:local noippass "PASSWORD"
# Set the hostname or label of network to be updated.
# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.
# To specify multiple hosts, separate them with commas.
:local noiphost "no-ip.org"
# Change to the name of interface that gets the dynamic IP address
:local inetinterface "GATEWAY"
# No more changes need
:global previousIP
:if ([/interface get $inetinterface value-name=running]) do={
# Get the current IP on the interface
   :local currentIP [/ip address get [find interface="$inetinterface" disabled=no] address]
# Strip the net mask off the IP address
   :for i from=( [:len $currentIP] - 1) to=0 do={
       :if ( [:pick $currentIP $i] = "/") do={
           :set currentIP [:pick $currentIP 0 $i]
# Get your previous IP address
   :set previousIP [:resolve $noiphost]
   :if ($currentIP != $previousIP) do={
       :log info "No-IP: Current IP $currentIP is not equal to previous IP $previousIP, update needed"
       :set previousIP $currentIP
# The update URL. Note the "\3F" is hex for question mark (?). Required since ? is a special character in commands.
       :local url "http://dynupdate.no-ip.com/nic/update\3Fmyip=$currentIP"
       :local noiphostarray
       :set noiphostarray [:toarray $noiphost]
       :foreach host in=$noiphostarray do={
           :log info "No-IP: Sending update for $host"
           /tool fetch url=($url . "&hostname=$host") user=$noipuser password=$noippass mode=http keep-result=no;
           :log info "No-IP: Host $host updated on No-IP with IP $currentIP"
   }  else={
       :log info "No-IP: Previous IP $previousIP is equal to current IP, no update needed"
} else={
   :log info "No-IP: $inetinterface is not currently running, so therefore will not update."
