6.29.1 - 802.1x Authentication Timeout
I’ve recently upgraded my AP’s (RP951G-2HnD) to 6.29.1. Since the upgrade, 802.1x clients are unable to authenticate against my RADIUS server, with the only error observed being in the MikroTik logs indicated a disconnected client (802.1x authentication timeout).
I’ve tried increasing the timeout, however this did not seem to make a change. Looking at my RADIUS server (Windows 2012 R2 running NPS) I don’t see the connection attempts at all.
Is anyone else experiencing this issue?
Thanks,
Tim
I’m having the same issue with my CCRs after upgrading to 6.29.1 and reverting back to 6.28 fixed every router having the problem. Odd thing is that the issue wasn’t happening on all the routers I upgraded but was very pronounced on 3 of them.
Perhaps I’ll have to revert then back from 6.29.1. I took a look at the change logs, and don’t see anything related to RADIUS. Further, looking at the beta change logs I don’t see anything that hints at a resolution for this.
MikroTik, any thoughts or interest in investigating this further?
