6.29.1 Internet Speed Drop
I was running 6.24 and was getting my full 150/10. Sense 6.29.1 I’m stuck at 30/10. I have done a reset and a stock configuration and tested with same results. I read that disabling the LCD is fixing this for some, but it has had no effect on mines. Is there a workaround to this issue ?
Can You please describe in little more detail? What routerboard model, your configuratin, what type of traffic and testing method, so we could try to reproduce the same results.
Thanks.
CRS125-24G-1S-2HnD
I even did a factory reset with 6.29.1. Stock configuration. I’m on 150/10. With 6.29.1 stock defaults the max download is in the 30 range. With 6.24 stock defaults I get around 130. I download the 6.24 and downgraded. With a sonicwall NSA220 I have here I get higher than the plan 168/10. These tests where done with hardware reset after applying 6.29.1 and 6.24 all stock.
The speed tests where done at speedtest.net using the same server. These tests where done multiple times to average out.
Forgot to add that this is with firmware 3.18 and the latest on routerboard’s site 3.19. I tried the tests with the same firmware on each version
The Mikrotik support told me to try following commands and that solved the throughput problem:
/queue type set ethernet-default pfifo-limit=100
/queue interface set [find] queue=ethernet-default
