6.30 RC final fixes before release
No changelog for 6.30rc23, so waiting for rc24 and final.
May I please ask to highlight changes per RC in changelog (like it was before for versions)?
And, if it is possible at all, to set Content-Disposition for http://www.mikrotik.com/download/share/routeros_devnote.txt to something that permits open it as plain text file? I hate to have other program to open simple text file.
Please, add a checkbox for turning off these dummy statistic rules for FastTrack. I don’t understand, why do we need them, since we have this counter on IP - Settings.
Yes. Let us choose to turn it on or off.
Why even those dummy rules? Put the values to the real rules correctly !
I find them very useful. Imagine situation when you need to connect to some unknown router and configure mangle and queue tree, you start mangling, but rules doesn’t see the traffic, you have no idea why, cause you can see traffic on interface …
Now you open mangle and you see that there are something - a rule that counting traffic - “aaaa, so there are my traffic”.. It really avoids lots of potential confusion. I had several e-mails from our customers already about this, after everyone enabled fasttrack.
Initial implementation had some bugs, but as far as i can see latest RC adressed that.
fasttrack for pppoe-client still not supported?
Is the queue tree bug fixed from 29? The one where if you make constant changes the queues stop working?
What about broken Simple Queues in Bridge configuration? 6.30rc22 (from 6.29, 6.30rc19,…)
http://forum.mikrotik.com/t/fasttrack-new-feature-in-6-29/87517/179
http://forum.mikrotik.com/t/fasttrack-new-feature-in-6-29/87517/177
It seems completely NO firewall, but IP Firewall box in Bridge Settings checked (screenshots).
All features worked OK until 6.27 .
I also saw issues with scheduled scripts not running and Netwatch scripts not executing on down/up. Has anyone else had this problem? I’m using rc23
did you wrote an email to support like i suggested in othre topic?
MikroTik RouterOS 6.30rc22 (c) 1999-2015 http://www.mikrotik.com/
jun/30/2015 11:49:08 ppp,error,critical pptp-vypervpn: Encryption got out of sync - disabling
jun/30/2015 11:58:38 ppp,error,critical pptp-vypervpn: Encryption got out of sync - disabling
jun/30/2015 13:58:10 ppp,error,critical pptp-vypervpn: Encryption got out of sync - disabling
jun/30/2015 15:35:52 ppp,error,critical pptp-vypervpn: Encryption got out of sync - disabling
Not sure if the Encryption out of sync is fixed yet…
It’s not. I saw this error until rc23. The test client is a macbook pro with gigabit wired connection to pptp server. On debian server there is no problem.
I hate to point out the obvious, but PLEASE fix the Leap Second crash on the TILE platform. I can not afford to have them all lock up like they did today.
i setup external storage of log
setup type remote: 192.168.1.11, port 514
setup rules for remote (error, firewall, info, script,system, warning, l2tp), byt to all of them transfer to external storage
i have next lines of logs
Jul  1 11:07:11 router.domain.com dns,packet <1.2.3.4.in-addr.arpa:PTR:2981=host1234*.omkc.ru>
Jul  1 11:07:11 router.domain.com dns,packet --- got query from 192.168.1.11:33391:
Jul  1 11:07:11 router.domain.com dns,packet id:5e68 rd:1 tc:0 aa:0 qr:0 ra:0 QUERY 'no error'
and nothin from setup type of logs
Of course, 6.30 will not be released until NTP package problem with Leap Second on CCR will be fixed.
v6.30rc24 is available now.
Does this mean that 6.29 has a known bug with leap second? That might explain why both our CCR crashed tonight.
yes, all RouterOS versions are affected if you use NTP package and CCR.
Trafficflow fix? 6.29 broke it, no egress + ingress netflows.
scripts is worked on RC24!
