6.30 released
What’s new in 6.30 (2015-Jul-08 09:07):
*) wireless - added WMM power save suport for mobile devices;
*) firewall - sip helper improved, large packets no longer dropped;
*) fixed encryption ‘out of order’ problem on SMP systems;
*) email - fix sending multiple consecutive emails;
*) fixed router lockup on leap seconds with installed ntp package;
*) ccr - made hardware watchdog work again (was broken since v6.26);
*) console - allow users with ‘policy’ policy to change script owner;
*) icmp - use receive interface address when responding with icmp errors;
*) ipsec - fail ph2 negitioation when initiator proposed key length
does not match proposal configuration;
*) timezone - updated timezone information to 2015e release;
*) ssh - added option ‘/ip ssh stong-crypto’
*) wireless - improve ac radio coexistence with other wireless clients, optimized
transmit times to not interfere with other devices;
*) console - values of $“.id”, $“.nextid” and $“.dead” are avaliable for
use in ‘print where’ expressions;
*) console - ‘:execute’ command now accepts script source in “{}” braces,
like ‘/system scripts add source=’ does;
*) console - ‘:execute’ command now returns internal number of running job,
that can be used to check and stop execution. For example:
:local j [:execute {/interface print follow where [:log info “$name”]}]
:delay 10s
:do { /system script job remove $j } on-error={}
*) console - firewall ‘print’ commands now show all entries including
dynamic, ‘all’ argument now has no effect;
*) ipsec - increase replay window to 128;
*) fixed file transfer on devices with large RAM memory;
*) pptp - fixed “encryption got out of sync” problem;
*) ppp - disable vj tcp header compression;
*) api - reduce api tcp connection keepalive delay to 30 seconds,
will timeout idle connections in about 5 minutes;
*) pptp & l2tp & sstp client: support the case were server issues its tunnel
ip address the same as its public one;
*) removed wireless package from routeros bundle package,
new wireless-fp is left in place and wireless-cm2 added as option;
*) pptp & l2tp client: when adding default route, add special exception route for
a tunnel itself (no need to add it manually anymore);
*) improved connection list: added connection packet/byte counters,
added separate counters for fasttrack, added current rate display,
added flag wheather connection is fasttracked/srcnated/dstnated,
removed 2048 connection entry limit;
*) tunnels - eoip, eoipv6, gre,gre6, ipip, ipipv6, 6to4 tunnels
have new property - ipsec-secret - for easy setup of ipsec
encryption and authentication;
*) firewall - added ipsec-policy matcher to check wheather packet
was/will be ipsec processed or not;
*) possibility to disable route cache - improves DDOS attack
handling performance up to 2x (note that ipv4 fastpath depends on route cache);
*) fasttrack - added dummy firewall rule in filter and mangle tables
to show packets/bytes that get processed in fasttrack and bypass firewall;
*) fastpath - vlan interfaces support fastpath;
*) fastpath - partial support for bonding interfaces (rx only);
*) fastpath - vrrp interfaces support fastpath;
*) fixed memory leak on CCR devices (introduced in 6.28);
*) lte - improved modem identification to better support multiple identical modems;
*) snmp - fix system scripts table;
is there any specific command needed to enable WMM Power Save of is it enabled by default. TNX … upgraded RB951G without issues.
JF.
No It just enabled by default on wireless-fp and cm2 packages
I could not get the regular wireless package be seen after uploading it to a router. What is the process to get it to be added to the packages? We see less disconnects with nstream with the regular wireless package than the fp or cm2 packages and need it for that reason.
Waiting a long time for this. Nice.
… there is no “regular” wireless package anymore…
‘execute’ in not running scheduler.
I just upgrades my CCR1009-PC
I now have problems on my bonding interface.
Its configured for active-backup. ether8 is master and ether7 is slave. If you disconnect the ethernet cable from ether8 you get an instant reboot with the following lines in the log/terminal:
System rebooted because of kernel failure
router was rebooted without proper shutdown, probably kernel failure
If you want to change the bonding interface, you will get the same instant reboot.
Is there a workaround/fix for this issue yet? Ist it even “on the radar”?
Otherwise the device is working well.
Thanks for any help :slight_smile:
Am I wrong or all_packages-smips-6.30.zip doesn’t contain the wireless package? And I can’t find it separately for download (capsman2 package).
It continues with the bugs that I reported. Apparently, you’re not behind the comments of members. This is sad.
I hope so many changes is going to work out.. Lets wait and see for two week if we will get a storm on this tread or just a mild breeze…
That’s not completely fair.. they must have worked hard to correct and introduce so many features. Some bugs just take time to figure out and fix. Maybe the are fixed in next release. Or ask them polite to their status. :slight_smile:
The bug is from the 6.29 version and has been reported in fixes topic 6.30 RC
They had to give priority to bugs than the news.
I was meaning I can’t find ANY wireless package: I don’t find both wireless-fp and wireless-cm2. I don’t think that SMIPS ever had the plain wireless package at all. Are the features included into the system package?
What version am I running ? :smiley:
but I still get the following in the log from my iphone 5s:
20:55:22 wireless,info wlan1: data from unknown device 54:E4:3A:27:06:F3, sent deauth
20:55:47 wireless,info wlan1: data from unknown device 54:E4:3A:27:06:F3, sent deauth
20:55:47 wireless,info 54:E4:3A:27:06:F3@wlan1: connected
20:57:45 wireless,info 54:E4:3A:27:06:F3@wlan1: disconnected, extensive data loss
6.30, wireless-fp enabled
And that can’t be the fact. If bugs always would have priority above new features we would still work with pigeons to send a message. They still have bugs…
Technology advances because new features are introduce to do better. Bugs are always around and some bugs only affect some specific users where new features probably benefit more and put a manufacturer still in the market.
Its a balance…
But lets not clutter this tread. I’m waiting for the first reports of success or failures from the wide users base…
It seems that managed to solve, after upgrading the firmware of my RB750. I will wait to see if the problem returns because the bug began after 15h uptime.
#Edit
The bug is still continuing. Only occurs when the port is connected but unused. Example: Using switch unmanaged.
By using the door with a computer for example, displays the correct data from the same use. Now, if the same stop using the door, and turns off when passing +/- 5 minutes, back to send packets from one port to the other, while the other is not in use, is connected only.
Be aware, There is a new routerboard firmware version 3.24 !!!
