6.33.1 Download
Anyone know where I can download this version? I would need the PowerPC version and the CCR version if possible. I’m having trouble getting my guest VLAN working properly and it worked in 6.33.1. I tried on a client router in 6.33.3 and couldn’t get it to work. I updated mine to rule out software and now mine doesn’t work. I also tried downgrading to the available 6.32.3 and the RC 6.34rc20. Neither of which worked. It may have nothing to do with the OS version but I want to get back to a known working state at my house to rule that out.
http://www.mikrotik-software.de/downloads/
You should Google first.
please make a supout.rif when something is not working, before you change the version. Send the file to support, this way we can fix it for everyone, if there is a problem in the software
Thanks, I did Google and found various downloads but I didn’t know which ones I could trust which is why I asked.
You can trust no one. The best is to make your own ros version gallery from the files downloaded from official site as the time goes… I have this but not with all versions as I consider only some of them to be important for me.
Anyway, there were some requirements to mikrotik to open their version library to public in order to enable everyone to download what he needs from official source, but they never did it. Probably they want everyone to go forward only.
Sometimes you can hack the download link and get the requested older files from official mikrotik site because the naming convention is not changed very often.
@normis
Why you dont have @mikrotik site archive for olds version
So ve can go back to old version
I stay with 6.29.1 sw, because every new version have some crititcal bug, in the past that was not happening.
We are now all beta testers with stable relese
I can recommend using the “bugfix only” downloads, they are the most stable versions.
You are not forced to upgrade, if everything works fine, just keep using what you have and don’t worry.
