6.33.1 version is released!
We have released new version of RouterOS 6.33.1 which is 6.33 with included fixes for known bugs. New features are not included.
What’s new in 6.33.1 (2015-Nov-17 09:55):
*) licensing - fix unneeded connection attempts to 169.254.x.x must be CHR only (introduced in 6.33);
*) pppoe - fixed compliance to RFC4638 for MTU larger than 1488 (introduced in 6.33);
*) CRS2xx - fixed occasional switchip resets (broken in 6.33);
*) fastpath - fixed wireless interface fastpath (broken in 6.33);
*) smb - fixed SMB share crash when connection was cancelled;
*) lcd - fixed LCD crash on fast disable/enable;
*) lcd - refresh LCD after display command is executed;
*) vrrp - fix enabling disabled vrrp interface when vrrp program has exited;
*) winbox - do not send any changes on OK button press if nothing has been changed;
*) www - put correct path to Winbox v3.0 for new installations with branding package;
*) webfig - show correctly SFP Tx/Rx;
*) winbox - renamed power-cycle-ping-interval to power-cycle-ping-timeout;
*) hotspot - fixed missing image at login;
*) netinstall - fix branding pack parsing;
*) packages - show version tag when no bundle is installed.
I think I found a little bug.
export shows this:
/tool romon port
add
On the previous 6.33 version it showed:
/tool romon port
set [ find default=yes ] cost=100 forbid=no interface=all secrets=""
add cost=100 disabled=yes forbid=no interface=all secrets=""
Something is missing :slight_smile:
I found this when I checked my Rancid diffs.
I do not get it - what is missing? all looks in order
What's new in 6.33 (2015-Nov-06 12:49):
*) romon - change port list to be not ordered in export;
Well, this is not a config that you can copy/paste in a router. The CLI expects some input after ‘add’.
Your initial config is the issue, fix it. and all problems will be gone.
As list behavior is already changed, and your config will not be common (cause of global romon option availability) , this is minor issue.
If you have had imported configuration from old export, then you will have this:
/tool romon port
add
If you will run “/tool romon port” print then now you will have two entries for port=all. You can delete one of them. Old export was incorrect and now if you import it, then it seems like it is incorrect again. If you have default RoMON configuration then starting from this version “/export” will be empty.
in rush i upgrade my home router and two of my customers to 6.33.1 from 6.33 and now i cannot connect to all of them with ip cloud. the customers also called me that they have no internet.
I don’t think I have ever imported old configuration on these devices. But removing one of the entries solved my problem. Thank you!
you are not doing it right. First test then upgreade yourself, then use for few days, and then and only then do something on customer network.
My upgrades have no issues so far.
yes of course i always do like this , i dont know today how i did this rushing bloody thing. i always upgrade my home router to play and after my customers!
@@@@@ now i have to go to the sites to check. i hope there is no need for netinstall
bad idea to install a new release only 3 or 4 hours after has been released to remote customer equipment
yes you are right!
i always install new version to my router at home and test. and after some days i install to my customers.
today i dont know i was tricked that is a bug release and no problems will appear!
three of them with ip cloud
please find out what specifically is the issue and let us know
i will go first to my house to check if i can connect to my rb2011 with winbox and see what is wrong.
if winbox is ok maybe something wrong with pppoe dialer and the bridge modem.
if cannot connect with winbox propably netinstall is required! after i pick up my laptop and go to customers.
i will inform what i have found in some hours!
PPoE-Out Client: DialIn to German Telekom not working on RB493AH.
RB439AH was running ok with V6.33, V6.33.1 didn’t do the dialin-process and ran into loop.
Login process always gets terminated.
Downgraded to V6.33 and everything worked ok again.
i am in greece and i use pppoe with 1492 mtu-mru to dial at bridge modem. maybe we have the same problem
this is a photo from customer of another rb951 at a previous version ros
It’s the same here: 1492/1492 - runs perfectly in V6.33
Same issues with PPPoE client on CRS-1xx - can’t test downgrading yet as need to go home to fix it :smiley:
just came home and rb2011 with 6.33.1 was ok except pppoe-out1 was in a loop and not connecting.
remove 1492 in both fields (see image below) and connected!
i am going to my 2 sites to do the same. i wont downgrade to 6.33
Yes… Pppoe not working, recived bad pap…
Rb435g and 493ah
Again fix will be needed 6.33.1.1
