I have set up a GNS3 simulated router using chr-6.35.2.img to mirror a production router running the same version in order to do testing. However in trying to recreate the config on the simulated router I found that the /interface ethernet master-port option is not present in the ROM, even though it is present on the production hardware system. I am aware that master-port has been deprecated as of v.6.41 but I still need it in the simulated environment to do testing. Notice in the listings below that the master-port option is missing from the emulated system even though both are using RouterOS v.6.35.2:
On the emulated sytem:
/system resource print
uptime: 5h48m44s
version: 6.35.2 (stable)
build-time: May/02/2016 10:09:26
/interface ethernet set ether20
Change properties of one or several items.
– List of item numbers
advertise –
arp – Address Resolution Protocol
auto-negotiation – When enabled the interface “advertises” the maximum capabilities to achieve the best connection possible
cable-settings – Ethernet cable type
combo-mode –
comment – Short description of the item
disable-running-check – Disable running check
disabled – Defines whether item is ignored or used
full-duplex – Defines whether the transmissionof data appearsin two directions simultaneously
l2mtu –
mac-address – MAC address
mdix-enable –
mtu – Maximum Transmit Unit
name – Interface name
orig-mac-address –
rx-flow-control –
sfp-rate-select –
speed – sets the data transmission speed of the interface
tx-flow-control –
On the production hardware system:
uptime: 2w4d15h14m2s
advertise –
bandwidth –
combo-mode –
l2mtu –
master-port –
mdix-enable –
orig-mac-address –
rx-flow-control –
sfp-rate-select –
tx-flow-control –
