6.36.2 / 6.39 is BUGGED!
I have two office, connected via two CCR (L2TP/IPSEC tunnel), and FreePBX in each office (192.168.1.10 and 192.168.2.10, connected via SIP trunk).
After upgrade to 6.36.2 i cannot call from one office to another.
In FreePBX log i see:
VERBOSE[29520][C-000000b3] pbx.c: Executing [s@from-sip-external:6] Log(“SIP/192.168.1.10-000000f8”, "WARNING,“Rejecting unknown SIP connection from 192.168.1.10"”) in new stack
WARNING[29520][C-000000b3] Ext. s: “Rejecting unknown SIP connection from 192.168.1.10”
only after downgrade to 6.34.6 calls work fine.
Not a bug, configuration issue.
Change Log of 6.35:
*) l2tp - implemented l2tp and lns fastpath/fasttrack support;
See this response here:
http://forum.mikrotik.com/t/v6-36-2-current-is-released/100926/1
"Note that not all packets in a connection can be fasttracked, so it is likely to see some packets going through slow path even though connection is marked for fasttrack. This is the reason why fasttrack-connection is usually followed be identical action=accept rule. Fasttracked packets bypass firewall, connection tracking, simple queues, queue tree with parent=global, ip traffic-flow(restriction removed in 6.33), ip accounting, ipsec, hotspot universal client, vrf assignment, so it is up to administrator to make sure fasttrack does not interfere with other configuration; "
http://wiki.mikrotik.com/wiki/Manual:IP/Fasttrack
No. Before upgrading CCR have 6.35.2, and calls also work fine.
6.39 also have this issue!
(6.37.5 work fine)
