After upgrade to 6.38 ipsec tunnel dont work.
I downgrade to 6.37.3 and tunnel work again.
Please make support output file and send it to support@mikrotik.com so we could see your configuration and reproduce this problem
The same actual problem. IPSec tunnels stop working after upgrade to 6.38, 6.38.1, 6.39.x
Downgrade to 6.37.3 restore ipsec tunels.
Any solutions?
Contact support with attached supout file. It is almost impossible to guess what ipsec config you have and what might not work.
I have a config that works for many years on any version before 6.38
It is incredible that Mikrotik release such bugged version.
This is absolutely unacceptable for enterprise.
Can’t make supout.rif
When progress 15% router going reboot. No files created in filesystem.
os version: 6.37.4
hw version: RouterBOARD 3011UiAS, firmware ipq8060, 3.35
I’m also having this problem.
Interestingly, ipsec for IPv6 between the same 2 routers works fine.
I sent a supout.rif file to MikroTik support. Hopefully they can fix it quickly since it was working fine before.
i’ve the same Problem after Upgrading from 6.38 to 6.38.1 Tunnel work for few hours /system resource print shows 100% CPU-Usage after 4 Hours /ip ipsec peers print no output /ip ipsec installed-sa print no output after Router Reboot it works again..
6.39 also have this issue and kill IPsec
Why mikrotik developers release bugged versions???
I don’t remember, when it started, but with version 6.40.3 I still have this problem. Load randomly rises over 80-90% (on a 16 core CCR, where normal load is 2-3%) and communication over IpSec tunnels stops. All other function, like routing between local ethernet ports, works well, IpSec connections seems established, but no communication over them.
After reboot it works, sometimes for a day, sometimes for a month.
I have the same issue. Two devices, both 6.43.4. HEX S and RB3011.
nov/22/2018 13:04:06 by RouterOS 6.43.4
software id = 52XB-TREB
model = RouterBOARD 3011UiAS
serial number = xxxxxxxxx
/ip ipsec peer profile
set [ find default=yes ] dh-group=modp4096,modp2048 enc-algorithm=
aes-256,aes-192,aes-128 hash-algorithm=sha256 nat-traversal=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc
pfs-group=modp2048
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=MyProposal
pfs-group=modp2048
add name=dhcp ranges=192.168.5.101-192.168.5.254
add name=static_pool ranges=192.168.5.1-192.168.5.100
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add address=192.168.5.1/24 interface=bridge1 network=192.168.5.0
add address=12.34.56.122/30 interface=sw1-e1-WAN network=12.34.56.120
/ip cloud
set ddns-enabled=yes
add address=192.168.5.0/24 gateway=192.168.5.1 netmask=24
set allow-remote-requests=yes servers=8.8.4.4,8.8.8.8
add action=accept chain=input connection-state=established,related
add action=accept chain=forward
add action=accept chain=forward connection-state=established,related
add action=accept chain=input in-interface=bridge1
add action=accept chain=input comment=ipsec-ike-natt dst-port=4500 protocol=
udp
“Test: Regel zum Surfen, Hausnetz, tcp” in-interface=bridge1 protocol=tcp
src-address=192.168.5.0/24
add action=accept chain=input comment=“allow IKE” dst-port=500 protocol=udp
add action=accept chain=forward comment=vpn01 dst-address=192.168.5.0/24
in-interface=sw1-e1-WAN ipsec-policy=in,ipsec src-address=192.168.2.0/24
add action=accept chain=forward comment=“Regel zum Surfen, vpn!”
in-interface=bridge1 protocol=tcp src-address=192.168.89.0/24
add action=accept chain=forward comment=ipsec-ike-natt dst-port=4500
in-interface=sw1-e1-WAN protocol=udp
add action=accept chain=forward comment=“allow IKE” dst-port=500 protocol=udp
add action=accept chain=input comment=test connection-state=“” protocol=
ipsec-esp
add action=accept chain=forward comment=test connection-state=“” protocol=
ipsec-esp
add action=accept chain=input comment=“allow pptp” dst-port=1723 protocol=tcp
add action=accept chain=input comment=“allow sstp” dst-port=443 protocol=tcp
add action=accept chain=input dst-port=53 in-interface=bridge1 protocol=tcp
add action=accept chain=forward comment=“Portforwarding pptp!” dst-port=1723
protocol=tcp
add action=accept chain=input src-address=192.168.89.0/24
add action=accept chain=forward dst-address=192.168.5.111
add action=accept chain=input dst-address=192.168.5.111
add action=drop chain=forward comment=“Regel zum Surfen”
add action=drop chain=input log=yes log-prefix=“Drop Input”
/ip firewall mangle
add action=mark-connection chain=forward comment=“Mark IPsec” disabled=yes
ipsec-policy=in,ipsec new-connection-mark=ipsec passthrough=yes
ipsec-policy=out,ipsec new-connection-mark=ipsec passthrough=yes
add action=accept chain=srcnat comment=vpn01 dst-address=192.168.2.0/24
add action=masquerade chain=srcnat comment=“masq. vpn traffic” src-address=
192.168.89.0/24
add action=masquerade chain=srcnat comment=“masq. vpn traffic” disabled=yes
add action=accept chain=srcnat disabled=yes dst-address-list=192.168.2.0/24
out-interface=sw1-e1-WAN src-address-list=192.168.5.0/24
add action=masquerade chain=srcnat disabled=yes out-interface=sw1-e1-WAN
add action=accept chain=dstnat comment=vpn01 dst-address=192.168.5.0/24
/ip firewall raw
add action=notrack chain=prerouting dst-address=192.168.5.0/24 src-address=
192.168.2.0/24
add action=notrack chain=prerouting dst-address=192.168.2.0/24 src-address=
192.168.5.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec peer
add address=65.43.21.132/32 comment=vpn01 exchange-mode=ike2 secret=
“geheim”
/ip ipsec policy
set 0 disabled=yes
add comment=vpn01 dst-address=192.168.2.0/24 proposal=MyProposal
sa-dst-address=65.43.21.132 sa-src-address=12.34.56.122 src-address=
192.168.5.0/24 tunnel=yes
add distance=1 gateway=12.34.56.121
add comment=vpn01 distance=1 dst-address=192.168.2.0/24 gateway=bridge1
add comment=vpn01 distance=1 dst-address=192.168.5.0/24 gateway=bridge1
/ip service
set telnet disabled=yes
set www address=192.168.5.0/24,192.168.89.0/24
set ssh address=192.168.5.0/24,192.168.2.0/24
set api disabled=yes
set winbox address=192.168.5.0/24,192.168.2.0/24
set api-ssl disabled=yes
Something is wrong.
Thanks in advanced
